philippe27 Champion du monde
![](modules/Forums/images/avatars/1685.gif)
Posté le: 24.09.2016, 19:58:33 Sujet du message: Chargeur SkyRC Ultimate Duo 400W AC/DC multi charger |
Balance Charger / Discharger / Power Supply
SKYRC D400 is a twin-channel charger with two independent circuits which can charge two different
kinds of batteries simultaneously. It also supports power distribution in AC/DC mode to get max charging power to shorten charging time.
Moreover, it is not only just a charger, but also can supply 150 Watts DC Power on channel 2, users can use it to power DC devices.
What’s more, the synchronization mode is available, in which users could perform synchronous settings for charging same batteries simultaneously to offer time-saving benefits
AD/DC
400W Duo Output
Support
Power Distribution
Employ
Synchronization Mode
Supply
150W DC Power
DC Output
DC Input
11-18V
Cooling Fan
Output Socket
4mm Banana Plug
Temperature Sensor Port
USB Port
Micro USB Port for PC Link
Balance Lead Socket
Power Distribution
It supports power distribution, for example,Channel 1-300w, then channel 2-100W, the total power is 400W. Please note the Max power of channel 2 is 200w, but that of channel 1 is 400W.
Employ this function, user can set both channel by
channel 1, that saves much time.
DC Power Supply
SkyRC D400 can supply 150 watts DC Power on channel 2. User can use it to power equipments that require DC Power. It converts standard 100-240V AC mains to 6-15V DC output.
Dimensions
Weight 2510g
Input Voltage AC 100-240V/DC 11-18V
Charge Circuit Power 400W
Discharge Circuit Power 36W
Charger Current Range 0.1-20A
Discharge Circuit Power 0.1-5A
Current Drian for Balancing Port Max 500mA/cell
Trickle Charging Current 50mA-300mA & OFF
DC Power Supply Output 6-15V/Max.10A
LiPo/LiFe/Lilon/LiHV Battery Cell Count 1-7S
NiMH/NiCd Battery Cell Count 1-18S
Pb Battery Voltage 2-24V
[img]Ultimate Duo 400W AC/DC
DC Power Supply
Dimensions
Weight 2510g
http://www.skyrc.com/index.php?route=product/product&product_id=236
file:///C:/Users/maman/Downloads/D400%20Charger%20Manual.pdf[/img] |
BALOO51 Expert*
![](modules/Forums/images/avatars/Perso/Subaroues_cogs04.gif)
Posté le: 19.11.2017, 18:06:13 Sujet du message: |
bonsoir,
quels sont les retours sur ce chargeur? |
Asromin Ligue
Inscrit le: 20/02/2012 Messages: 145 Localisation: Montpellier
Posté le: 19.11.2017, 20:15:57 Sujet du message: |
un collègue la il a fait le saison avec je chargé mes accus plus les siens en compétions franchement super chargeur !!! ![OK!](modules/Forums/images/smiles/ok.gif) _________________ Xray xb8e / Ultimande MZ8 / Servo Sanwa PGS-XBII / Sanwa MT44 |
BALOO51 Expert*
Posté le: 24.06.2018, 10:23:30 Sujet du message: |
bonjour,
combien d'ampère faut-il mettre en courant de décharge pour le stockage des lipos? |
TOM10 Ligue
Posté le: 24.06.2018, 11:26:43 Sujet du message: |
Ce chargeur délivre une puissance de 36W en décharge, ce qui te donne pour une 4S chargée un courant de décharge max d'un peu plus de 2A.
Tu peux y aller à 2A sans problème et ça reste long pour passer en stockage, sachant que à 1C en décharge comme en charge faut compter environ 1h.
Bonne journée. |
BALOO51 Expert*
Posté le: 24.06.2018, 12:52:31 Sujet du message: |
2A pour des 4500 et 6000mah? |
TOM10 Ligue
Posté le: 24.06.2018, 15:11:13 Sujet du message: |
Pourquoi ? Qu'est ce qui te choque ?
Comme indiqué le chargeur de ce post ne pourra pas débiter plus de 2A en courant de décharge pour une 4S chargée...
Sinon pour les batteries que tu cites, le courant max de décharge sera (dans l'ordre cité):
4,5 x nbre de C= x A & 6 x nbre de C= x A |
mika Ligue
Inscrit le: 21/11/2006 Messages: 275 Localisation: grenoble/chirens
Posté le: 25.06.2018, 08:15:56 Sujet du message: |
TOM10 a écrit: | Bonjour,
Bonne journée. |
tu peux aller bien au dessus de 1C en décharge, quand tu te sers du lipo sur la rc, on est bien au dela ... |
TOM10 Ligue
Posté le: 25.06.2018, 09:55:35 Sujet du message: |
Bien sur, j'ai déjà répondu au courant maximal de décharge dans le post juste au dessus!
Mais la question porte sur la décharge à partir de son chargeur / déchargeur et là tu es limité à la puissance de décharge de ton équipement et dans le cas du chargeur cité c'est 2A max avec un 4S chargé... |
mika Ligue
Posté le: 25.06.2018, 10:52:35 Sujet du message: |
bien sur
j'avais pas compris comme cela ...
![Wink](modules/Forums/images/smiles/icon_wink.gif) |
