RCmag :: Voir le sujet - Team Associated CR12 Ford F-150 RTR pick-up
MessagePosté le: 18.05.2018, 11:57:20    Sujet du message: Team Associated CR12 Ford F-150 RTR pick-up Répondre en citant
MessagePosté le: 18.05.2018, 11:58:09    Sujet du message: Répondre en citant
MessagePosté le: 18.05.2018, 11:58:35    Sujet du message: Répondre en citant
1:12 Scale Ready-To-Run Electric 4X4 Off Road Pick-Up Truck
The CR12 Trail Series 4x4 truck may be small in size, but it is packed full of features. This rig comes Ready-To-Run with Reedy Power electronics and meets S.O.R.R.C.A. class 1 and 2 rules right out of the box. No need to prep or build your rig; just charge it and you're ready to hit the trails!
Designed not only for scale looks with realistic wheels, tires and a licensed Ford F-150 Pick-Up body, the CR12 is built for performance as well. The steel ladder frame chassis provides the perfect backbone for this rugged little rig. The 4-link suspension, threaded shocks, and soft rubber tires give the grip and performance needed to climb over the roughest terrain. Transferring power to the rocks is a compact 3-gear transmission, front steel CVA axles, and includes metal-shield ball bearings.
Get ready to hit the trails -- and look good while doing it -- with the CR12 Trail Series 4x4 truck!
Ford Motor Company Trademarks and Trade Dress are used under license.
Features
Metal front CVA and rear solid axle shafts with 12mm hex adapters
Metal 4-link front and rear suspension
Fully adjustable, threaded, fluid-filled shocks
Chassis-mounted steering (CMS) servo
13.98:1 ratio 3-gear transmission with integrated motor mount
16-piece metal-shield ball bearing set
2.4GHz XP transmitter and receiver
Water-resistant Reedy Power speed control with high-current T-plug connector
850mAh Li-Ion 7.4V 2-cell battery and USB charger
Reedy brushed 380 motor
Black anodized aluminum battery/radio tray with hook and loop hold-down strap
Spring-loaded, heavy-duty servo saver
Official Licensed 1980 Ford F-150 custom Flareside body. Two body colors to choose from.
Chrome-plated front/rear bumpers and grill
4-piece High Intensity LED Set
Chrome-plated scale 1.55 wheels with soft compound off-road tires
MessagePosté le: 18.05.2018, 11:58:59    Sujet du message: Répondre en citant
Camion pick-up 4x4 électrique prêt à l'emploi, échelle 1:12
Le camion CR12 Trail Series 4x4 peut être de petite taille, mais il est plein de fonctionnalités. Cette plate-forme vient Ready-To-Run avec l'électronique Reedy Power et répond S.O.R.R.C.A. règles de classe 1 et 2 dès la sortie de la boîte. Pas besoin de préparer ou de construire votre plate-forme; il suffit de le charger et vous êtes prêt à frapper les sentiers!
Conçu non seulement pour l'apparence d'échelle avec des roues réalistes, des pneus et une carrosserie Ford F-150 Pick-Up sous licence, le CR12 est également conçu pour la performance. Le châssis à châssis en échelle en acier fournit l'épine dorsale parfaite pour cette petite plate-forme robuste. La suspension à 4 bras, les amortisseurs filetés et les pneus en caoutchouc souple offrent l'adhérence et les performances nécessaires pour grimper sur les terrains les plus accidentés. Transférer l'énergie aux roches est une transmission compacte à trois vitesses, des essieux avant en acier CVA, et comprend des roulements à billes à blindage métallique.
Préparez-vous à parcourir les sentiers - et regardez bien en le faisant - avec le camion 4x4 CR12 Trail Series!
Les marques de Ford Motor Company et Trade Dress sont utilisées sous licence.
Caractéristiques
Essieux avant CVA et arrière pleins en métal avec adaptateurs hexagonaux de 12 mm
Suspension avant et arrière à 4 bras en métal
Amortisseurs entièrement réglables, filetés et remplis de liquide
Servo de direction monté sur châssis (CMS)
13.98: 1 rapport de transmission à 3 vitesses avec support de moteur intégré
Jeu de roulements à billes à 16 pièces en métal
Transmetteur et récepteur 2.4GHz XP
Régulateur de vitesse Reedy Power résistant à l'eau avec connecteur T-high-current
850mAh Li-Ion 7.4V batterie 2 cellules et chargeur USB
Reedy brossé moteur 380
Batterie / plateau radio en aluminium anodisé noir avec sangle de retenue à boucles et crochets
Servo-économiseur à ressort, robuste
Carrosserie officielle Flareside 1980 Ford F-150. Deux couleurs de corps à choisir.
Pare-chocs avant et arrière chromés et gril
Ensemble de 4 DEL à haute intensité
Roues à l'échelle chromée 1.55 avec des pneus tout-terrain soft
MessagePosté le: 18.05.2018, 14:35:32    Sujet du message: Répondre en citant
