RCmag :: Voir le sujet - Redcat TR-MT8E BE6S
Redcat TR-MT8E BE6S
philippe27
MessagePosté le: 14.08.2016, 18:11:20    Sujet du message: Redcat TR-MT8E BE6S Répondre en citant
Redcat TR-MT8E BE6S
Specifications
Motor TypeElectric Brushless
TransmissionForward & Reverse
Length560mm
Width440mm
Wheelbase350mm
Ground Clearance88mm
ShocksAluminum Body Oil Filled Shocks
Speed ControlBrushless ESC 150A
BatteryNot Included - Requires Qty 2 LIPO 2s Batteries with Deans Plugs & Charger
Radio System2.4GHz Radio System
Team Redcat is a new high-end brand of premium vehicles introduced by Redcat.
The TR-MT8E BE6S is a highly upgraded version of the popular MT8E and includes the following upgrades.
Aluminum gear box
Center differential set with steel case
Aluminum quick release battery fastener with mount
Aluminum slide-type motor mount
Machined spiral bevel gears
Metal bevel gear case
Larger sized diff joint
Aluminum big bore shocks
Steel shock pivot ball
Aluminum uprights for rear wing
Low profile mounted tires
Larger wheels
Large 5mm thick shock towers
6S Waterproof 150a Hobbywing Max 8 ESC
The TR-MT8E BE6 is ready to run right out of the box, just add your own LIPO batteries.
The review below references the TR-MT8E and is not the BE6S upgraded version shown above. When new reviews and videos are done, Redcat will update this page.
See the TR-MT8E BigSquidRC.com review of this vehicle HERE
philippe27
MessagePosté le: 14.08.2016, 18:13:33    Sujet du message: Répondre en citant
gamme
http://www.redcatracing.com/Scale
MessagePosté le: 14.08.2016, 18:15:18    Sujet du message: Répondre en citant
moteur central en position haute comme le proto tecrace.
philippe27
MessagePosté le: 14.08.2016, 19:47:39    Sujet du message: Répondre en citant
[url][/url]
