RCmag :: Voir le sujet - Chargeur Turnigy T100 touch screen
aramis14
MessagePosté le: 04.10.2015, 21:57:25    Sujet du message: Chargeur Turnigy T100 touch screen Répondre en citant
Bonjour à tous
Je souhaiterai savoir si certain utilise ce chargeur et avoir leur avis
Merci d'avance
A bientot
Mes pages perso
aramis14
MessagePosté le: 13.10.2015, 17:07:52    Sujet du message: Répondre en citant
donc appartement il n'y a pas d'utilisateur encore il doit être trop jeune sur le marché.
Sinon a défaut quelqu'un pourrai me donner son avis sur cette marque.
cordialement
A bientot
Mes pages perso
philippe27
MessagePosté le: 13.10.2015, 22:30:45    Sujet du message: Répondre en citant
he Turnigy T100 Multifunction Touch Screen Charger is a next generation full function charger at the price of a basic charger. Packed full of features that you would expect on much more expensive units, the T100 will be your new take anywhere charger. Not only does it have the flexibility of being an AC/DC charger but it also has the ability to charge the new LiHV batteries.
Don't let its small size fool you either, this is a powerful little device able to charge at up to 10amps and discharge up to 5amps; it even includes a 5v USB port to charge devices such as phones, cameras and other portable devices.
The large 320x480px LCD screen is super sharp and easy to read under most conditions and is simple to use even for those of us with XXXL fingers. It even comes with a Micro USB port so you can hook it up to your PC to see charge logs and for firmware updates.
So if you've been looking for a powerful charger for home or out in the field you need look no further, the Turnigy T100 is here.
Features:
• Touch screen control
• Support LiHV battery
• 5V/2.1A USB port for charging Phones/MP3/other devices
• Micro USB port for PC Communication and Firmware Upgrade
• External temperature port
• Safety cut-off function (Voltage/Temperature/Capacity/Time)
Specs:
DC Input Voltage: 11-30V
AC Input Voltage: 100-240V
Display Type: 320x480 LCD
Size: 115mm x 168mm x 54mm
Weight: 580g
Battery Types / Cells: LiPo/Lilon/LiFe/LiHV 1~6S,NiMH/NiCd 1~15S, Pb 2~20V
Max Charge: 100W
Max Discharge: 10W
Charge Current Range: 0.1~10.0A
Discharge Current Range: 0.1~5.0A*
Balance Current: 300mA/cell
Memory: 10 Profiles
*Note: Discharge current subject to battery capacity and type.
PRODUCT ID: 9052000085-2
aramis14
MessagePosté le: 14.10.2015, 20:18:02    Sujet du message: Répondre en citant
mais tout cela je le savais déja, ma question n'etait pas là.
Moi ce qui m'interesse comme informations, c'est plus des retours d'utilisateurs des resentis, les omission des descriptifs
par exemple ils disent 100W max mais avons nous accés au 100W en AC ou DC ou les deux.
Hélas les marcahnds et les fabricants mettent rarement les notices en ligne pour avoir toutes ces précisions qui ont une importance et qui font la différence entre les chargeurs.
merci quand même
A bientot
Mes pages perso
philippe27
MessagePosté le: 14.10.2015, 21:23:01    Sujet du message: Répondre en citant
Bonsoir
C'est toujours intéressant de présenter un nouveau produit
