RCmag :: Voir le sujet - Transpondeur MRT PTX-20 Version 2
philippe27
MessagePosté le: 26.04.2015, 22:15:50    Sujet du message: Transpondeur MRT PTX-20 Version 2 Répondre en citant
est il utilisable sur nos système de comptage ????
Transponder passend für AMBrc und AMBrc3 Zeitmessanlagen.
Ideal für alle Anwendungen im RC-Modellsport.
Jeder Transponder hat eine eigene Nummer und zusätzlich die Möglichkeit 20 feste Nummern einzustellen.
- Kabelzuleitung ca.19 cm Robbe / Uni Stecksystem
- 22x16x7 mm (lxbxh)
- wasserdicht und kraftstofffest
- Gewicht ca. 3g ohne Kabel
- 2,8 - 30 Volt Gleichstromversorgung
- Stromverbrauch ca. 7,5 mA bei 6 Volt
- Stromversorgung direkt aus dem Empfänger
- LED zur Funktionskontrole
- Temperaturbereich 0 - 50 Grad Celsius
capsul
MessagePosté le: 26.04.2015, 23:13:43    Sujet du message: Répondre en citant
salut ca depend des clubs si ils ont un decodeur RC4 ca ne marche pas sauf si c'est des transpondeur MRT PTX-20 (NS)
Citation:
MRT Transponder, PTX-20 (NS) On this new version, the LED flashes twice when it's powered up to show it's the NS version and works with the new mylaps RC4 decoder, old MRT transponder comes on with no flash.
These transponders from MRT are lightweight and small in size. This makes them easy to fit into the smallest, tightest areas. The transponder in the main picture above has had it's mounting flanges trimmed off. Some drivers want them on there, some don't. Ours have the tabs so you can leave them or trim them (see photo below).
The PTX ID number of each transponder can be changed by use of a 'setup' button (20 alternative ID numbers are available). Each individually numbered transponder has its 'custom' ID number written on the supplied instruction sheet with the 20 alternative numbers also listed as two sets of 10 ID's.
PTX transponders are supplied with 20 stored ID numbers and come factory set on the custom ID. By pressing the setup button it is possible to switch from the custom number to the other numbers if required. To use the PTX it should be connected to a power socket on a receiver or to a battery pack. The LED will light up to show the transponder is operating. When setting the number (or checking the number that is set) the LED will flash to show the number selected, or the number that has been set.
Weight: with the long power lead and mounting tabs as shown below is 5 grams.
Compatibility: AMBrc2, AMBrc3 and RC4 systems.
http://www.stormerhobbies.com/cgi-bi...src&pn=MRT2000
<Update 8-AUG-2013>
For those with older versions of the MRT, you can upgrade to the NS free of charge by sending your PT to MRT with the following form:
http://www.team-mrt.com/ptx_form.pdf
*** The only catch is that you must purchase a new PTX ($64) when exchanging the old one, more details here: http://www.rctech.net/forum/radio-el...e-pt-news.html
Send in old PTX with form filled out + cost for new PTX, then get 2 new PTX's shipped back
(Last edited by BillDeLong : 8.08.13 at 7:34 am)
Lucas .S
Agama Team
Ligue 13 ARCC
philippe27
MessagePosté le: 27.04.2015, 11:03:30    Sujet du message: Répondre en citant
je remets ton lien
http://www.stormerhobbies.com/cgi-bin/seekpart.pl?pn=MRT2000
MRT Personal transponder with Fixing Tabs
PTX-20NS compatible with RC4 Timing System
Supplied with 20+1 Stored ID's (+1 Custom ID or Cloned ID)
Case version: 22 x 16 x 7mm, waterproof and fuel proof
Weight: approx 3g case
Mounting: direct fitting base or Tab
Temperature range: 0-50 C
Power feed: from a free RX channel (or Battery)
Power lead: approx 190mm or custom (replaceable lead)
Connection plug: standard servo plug
Digital Transponder
Compatible with AMBrc and AMBrc3 Systems
Operating voltage: 2.8V - 30V DC
Power consumption: approx 7.5mA @ 6V DC
Display LED: standard Blue
http://www.team-mrt.com/mrtwebshop/ptx-products-16301-0.html
https://www.google.fr/search?q=MRT+PTX&biw=1920&bih=946&source=lnms&tbm=isch&sa=X&ei=-Ag-VY2tB86KaKvTgdgN&ved=0CAcQ_AUoAjgK
