RCmag :: Voir le sujet - Montage du MBX-7R Mugen Seiki
Montage du MBX-7R Mugen Seiki Aller à la page Précédente  1, 2, 3, 4, 5, 6, 7  Suivante
perche
MessagePosté le: 06.11.2014, 10:27:39    Sujet du message: Répondre en citant
Sur le 7 aussi ça coinçait si on mettait la rondelle côté couronne, enfin sur le miens tout du moins.
speedy2
MessagePosté le: 06.11.2014, 11:21:46    Sujet du message: Répondre en citant
article tuning sur le MBX 7R by lee Martin
http://l-m-racing.co.uk/?p=660
MBX7R
Things in which i have currently found you can run differently to your old MBX7 set ups;
- Running without the underdriven rear gear box on looser surfaces; With the new drivetrain that the R has, it accelerates more smoothly and consistently. This means that when before you felt that you needed to run the underdrive to help pull the car out of the corner, you in fact probably no longer need to. The smoother pick up in speed is much easier to control and you will be faster if you can drive without it thanks to increased drive out of the turns.
- Rear shock position; Now we have a lower shock tower, I have felt it most comfortable in the inside hole on the arm. When using this hole i advise that you start with 116mm droop. On low to medium track surfaces this helps the car to rotate smoothly and land and drive forward more off of jumps. When high traction, fast tracks, I tend to revert back to the outside hole and use between 118-120mm droop.
- Harder rear shock springs – This is due to also running the inside hole. I have found that we can use much harder springs in the rear, don’t be afraid to try 10.50 or 10.25 springs to hold the rear of the car up on power.
- Thicker diff oils – Once again, due to our forgiving drivetrain we can run thicker diffs in our cars. Thick diffs are fast! the problem with them is that they are more difficult to drive and that trade off is where the set up has to be right. If you are feeling comfortable with good grip levels, don’t be afraid to thicken them diffs up! We ended up running 30,000-30,000-15,000 at the worlds and I took this set up to a damp UK track and it really wasn’t that bad!
- Something to test: Another thing I have liked is running a 44T spur gear with 42-12 (underdriven) front & rear gears. This allowed us to move the engine further to the centre of the car by over gearing it, then reducing our overall gear ratio by reducing the front and rear gears. This also reduces the weight of the car and the drivetrain. Less rotating mass makes for a faster accelerating car!
There are a few helpful tips on the R! now i advise you go out and buy one to try them out!!!!!
Modérateur le 06.11.2014, 14:49:02; édité 1 fois
didier2702
MessagePosté le: 06.11.2014, 13:45:25    Sujet du message: Répondre en citant
bidou_53 a écrit:
Il y a tant de différence de comportement que ça entre le 7 et le 7R? Pas juste des différences de choix technique?
Mes commentaires sont tout a fait personnel cependant le comportement est un peu different . Le 7 est a mon gout plus punchy , plus agressif et j'avais vraiment du mal a tenir la voiture; Le 7R est clairement moins agressif est plus lineaire sur les fortes accelerations. ca motrice vraiment fort tout comme le 7 cependant de facon moins brutale.
En fin d'apres midi apres le boulot (Je vis en Asie et avons 7 heures d'avance sur vous), nous avons tourné sur la piste et j'ai pu encore une fois bruler un reservoir. La voiture est maintenant completement rodée et ca a été un vrai regal .
Je suis en train de finir le montage de la mienne et j'ai prevue de roder mes diff Samedi matin et j'irais tourné sur notre piste vers 14H00 avec d'autres copains qui viennent aussi d'acheter le 7R. Je ferais des photos et une petite video.
A+
Mugen Seiki MBX7R + OS speed 2+ EFRA 2042
Mugen Seiki MBX6R US edition + OS 2101 + Jamming JP1
Radio : futaba 4pks-r
Ligue 2
www.smartech.fr
Bens93
MessagePosté le: 06.11.2014, 14:50:54    Sujet du message: Répondre en citant
Je suis impatient de monter le mien
Mdp177
MessagePosté le: 06.11.2014, 20:54:58    Sujet du message: Répondre en citant
didier2702 a écrit:
Je suis en train de finir le montage de mon 7R et j'ai constaté que le Diff Avant coincait un peu si on suit la notice , j'ai du mettre la la rondelle de calage a l'opposé de la courronne . Par contre pas de souci sur le diff arriere.
A+
J'ai expliqué sur un post précédent ce soucis , et j'ai envoyé un message a carson wernimont qui m'a conseillé de laisser comme ça , de roder les diffs en statique , et de controler aprés 10-15 min .. Mais de ne pas mettre coté opposé .. Rolling Eyes
MessagePosté le: 06.11.2014, 21:34:39    Sujet du message: Répondre en citant
j'ai deja expliqué dans un post la facon de roder les diffs avant montage definitif sur la voiture
ca permet de faire le calage parfait avant montage sur la voiture
ca necessite une perceuse et un vieux cardan .....et un petit 1/4h
aldo83
MessagePosté le: 06.11.2014, 22:16:54    Sujet du message: Répondre en citant
Moi je met une rondelle côté opposé à la couronne à l'avant et à l'arrière et ce depuis que j'ai des mugen et jamais le moindre problème et une très bonne roue libre Rolling Eyes
Après chacun fait comme il le sent, moi je suis pour le libre et même très libre Laughing
Pierre77
MessagePosté le: 08.11.2014, 16:53:53    Sujet du message: Répondre en citant
Petit zoom sur les nouveaux cardans mais à l'arrière cette fois =
[/URL]
Mugen MBX-7R, Ninja et AKA !
Merci GVP Racing, Top Options et mon papa !
Driver
MessagePosté le: 09.11.2014, 09:28:09    Sujet du message: Répondre en citant
Allez Pierre encore des photos.
Mugen59
MessagePosté le: 09.11.2014, 17:21:33    Sujet du message: Répondre en citant
fait tellement joujou avec qu'il a pas le temps de penser a nous Laughing
TT 1/8 Mugen mbx6 R
1 thermique + 1 brush
jb53
MessagePosté le: 09.11.2014, 19:52:14    Sujet du message: Répondre en citant
Bonjour à tous ,
Quelqu'un connaît la longueur total des cardans AV et AR svp ?
Asso RC8B4
ND1970
MessagePosté le: 09.11.2014, 20:04:58    Sujet du message: Répondre en citant
MBX7R
Bonsoir, suis pas bon du tout en anglais, quelqu'un pourrait traduire ces explications?
Merci d'avance.
GazGaz74 sur les autres forums
Gaulois Power
Mamare
MessagePosté le: 09.11.2014, 23:08:56    Sujet du message: Répondre en citant
MBX7R
Merci d'avance.
Tu veux pas qu'on te prete des doigts aussi ???lol Arrow --------->>>
MessagePosté le: 09.11.2014, 23:27:09    Sujet du message: Répondre en citant
en gros il dit qu'il a joué avec des gros diffs de 30/30/15 et que ca lui convenait bien et il dit de ne pas hesiter a essayer
....enfin si j'ai bien compris ...parce que moi non plus je ne comprends pas tout bien cette langue Laughing Laughing Laughing
Driver
MessagePosté le: 10.11.2014, 07:30:03    Sujet du message: Répondre en citant
Il dit aussi qu'il aime bien rouler avec une couronne de 44 et des diffs avant et arrière en 42 et pignon de 12. Ce qui doit correspondre à la prépondérance. Mais applique à l'avant et et l'arriere.
Nemo77
MessagePosté le: 10.11.2014, 11:13:12    Sujet du message: Répondre en citant
Rapport du mbx6r
Il tire n poil plus long qu un mbx6r
speedy2
MessagePosté le: 10.11.2014, 12:35:14    Sujet du message: Répondre en citant
Traduction:
Possibilités envers l’ancien MBX7 :
- On peut y aller sans le rapport underdriven dans la cellule arrière sur des surfaces plus glissantes;
Avec la nouvelle transmission, la R accélère plus en douceur et de manière cohérente. Cela signifie que lorsque vous avez senti avant que vous aviez besoin du underdrive pour aider à tirer la voiture du virage, vous en avez probablement plus besoin.
Le prise de vitesse plus douce est beaucoup plus facile à contrôler et vous sera plus rapide si vous pouvez conduire sans elle, grâce à l'augmentation de la vitesse en sorties de virages.
- Position des amortisseurs arrière;
Maintenant, nous possèdons un support plus bas, je me suis senti plus à l'aise avec la vis de rotule dans le trou à l'intérieur sur le triangle.
Lorsque vous utilisez ce trou, je vous conseille de commencer par 116mm de débattement. Sur les pistes à attérence basse ou moyenne, cela aide la voiture à contourner doucement les courbes et d'attérir et avancer directement après des sauts.
Lorsque la traction est élevée, et sur pistes rapides, j’ai tendance à revenir vers le trou à l'extérieur et d’utiliser entre 118-120mm de débattement.
- Ressorts d'amortisseurs arrière plus dur - Cela est dû auusi à l’utilisation du trou intérieur.
J'ai remarqué que nous pouvons utiliser des ressorts beaucoup plus dur à l'arrière, ne pas avoir peur d'essayer les ressorts 10.50 ou 10.25 pour faire tenir l'arrière de la voiture en accélérant.
- Les huiles de diff plus épais -
Une fois de plus, en raison de notre transmission douce nous pouvons utiliser des huiles de diffs plus épais dans nos voitures.
Des huiles de diffs épaisses sont rapides! le problème avec cela, est qu'ils sont plus difficiles à conduire donc le set-up doit être exact.
Si vous vous sentez à l'aise sur une piste à adhérence, ne pas avoir peur d'épaissir les diffs !
Nous avons fini la course aux Worlds avec du 30,000-30,000-15,000 et après, lors d’un essai sur une piste humide au UK, cela n’était vraiment pas si mal que ça!
- Autre chose à tester:
ce que j’ai aussi aimé est d’utiliser une couronne de 44 dts avec les rapport 42-12 (underdriven x 2) dans les cellules avant et arrière.
Cela nous a permis de positionnér le moteur plus au centre par surdémultiplication, puis la réduction de notre rapport de démultiplication global en réduisant les ratios avant et arrière.
Cela réduit également le poids de la voiture et de la transmission. Moins de masses en rotation permettent une accélération plus rapide voiture
Modérateur le 10.11.2014, 15:09:02; édité 6 fois
rc13milles
MessagePosté le: 10.11.2014, 12:39:49    Sujet du message: Répondre en citant
sur mon 7r les cardan arrière touche les triangle en débattement maxi.. qui a eu le même problème ?
mugen
MessagePosté le: 10.11.2014, 14:08:45    Sujet du message: Répondre en citant
Est ce que les cardans sont les meme que KYOSHO,si quelqu'un as les deux pour comparer
MUGEN JCA 4x2,1700kv,6mik
MUGEN MBX8 eco,Hobbywing et Hacker,Mt44,james
MUGEN MGT7 eco,Hobbywing et un 1900KV,GRP
Mdp177
MessagePosté le: 10.11.2014, 17:20:44    Sujet du message: Répondre en citant
La il parle du world donc c'est pas vraiment une base de réglage à suivre Wink
Sauf si vous rouler en Rally game ou sur mars !
Spyro1
MessagePosté le: 10.11.2014, 18:01:05    Sujet du message: Répondre en citant
J'ai surtout hate qu'ils sortent la version -7T"R"!!!!!
Tongy
MessagePosté le: 10.11.2014, 18:08:49    Sujet du message: Répondre en citant
Dans 1an alors grrr
Car le X7 Eco TRUGGY est sortie le 8 Mai de cette année Wink
MessagePosté le: 10.11.2014, 19:50:28    Sujet du message: Répondre en citant
......pas forcement , car avec le 7 on a fait des essais avec bien plus que 30000 et c'etait loin d'etre inconduisible ....c'etait meme bluffant
......mais c'etait avec le 7 Idea
ND1970
MessagePosté le: 10.11.2014, 20:42:09    Sujet du message: Répondre en citant
speedy2 a écrit:
Traduction:
Merci speedy, OK!
Gaulois Power
Pierre77
MessagePosté le: 11.11.2014, 09:24:15    Sujet du message: Répondre en citant
Photo des amortisseurs =
[/URL]
Ce sont les nouveaux amortisseurs, ils sont désormais plus large. Il mesure maintenant 16mm de diamètre. Ils permettent d'être plus stable sur les gros sauts ou sur les pistes défoncés.
A noté également que Mugen préconise maintenant 550 à l'avant et à l'arrière (sur le MBX-7, il préconisait 500 partout). Nous pouvons également constater l'apparition des nouveaux pistons 8*1,3 (si je dis pas de bêtise).
Mdp177
MessagePosté le: 11.11.2014, 22:51:24    Sujet du message: Répondre en citant
8x1,2 non ?!
Nemo77
MessagePosté le: 11.11.2014, 22:59:22    Sujet du message: Répondre en citant
non mr, source mugen.eu (site internet) 8x1.3 Wink
Driver
MessagePosté le: 12.11.2014, 08:14:28    Sujet du message: Répondre en citant
Mugen a fourni directement les ressorts 9,25 à l'avant et 10,75 à l'arrière. Bravo!
AlexisMbX
MessagePosté le: 12.11.2014, 11:39:42    Sujet du message: Répondre en citant
conique ou pas ?
Alexis CRYO CLEMENT
rc13milles
MessagePosté le: 12.11.2014, 11:46:52    Sujet du message: Répondre en citant
non conique
Page 4 sur 7
