RCmag :: Voir le sujet - S-POWER S5 Pro Tuned Off-Road .21 Competition Buggy Engine.
philippe27
MessagePosté le: 01.03.2016, 08:44:09    Sujet du message: S-POWER S5 Pro Tuned Off-Road .21 Competition Buggy Engine. Répondre en citant
S-POWER is a new series of Engine from S-workz that will provide you with World Champion Performance.
These Engines have a 3 port piston Sleeve for better power delivery and lower fuel consumption.
This is the S-POWER S5 Pro Tuned Off-Road .21 Competition Buggy Engine.
Developed to have the performance of the S-Power S7 Evo but at a lower Price.
The TUNED S5 Pro features a tungsten-balanced and silicone-ramped crankshaft.
A Blue lightweight, low-gravity cooling head with a Dragon logo.
These features allow the TUNED S5 Pro to deliver instant throttle response and powerful torque over the entire rpm range.
Features:
3-port sleeve design (3 bypass ports, 1 exhaust) provides smooth, crisp acceleration.
This has been achieved through a combination of a specially designed "TUNED" inner head and sleeve porting.
Fuel mileage has been improved by 8%.
Carburetor:
A newly designed carburetor includes 6.5mm aluminum venturi.
Crankshaft:
The crank intake passage is silicone ramped for a better fuel mixture flow.
A tungsten insert is pressed in the counterweight to optimize inertia mass.
Includes:
Exhaust Gasket.
Dust Cap Set.
6.5mm Carburetor Venturi.
The S-POWER Engines are Made in Japan by the leading R/C Engine Manufacturer O.S.
Specifications:
Displacement: 3.49cc (0.21 cu.in)
Bore: 16.27mm (0.64in.)
Stroke: 16.8mm (0.66 in.)
Practical R.P.M. : 4000~40000 r.p.m
Power output: 2.6 ps/ 34000 r.p.m.
Weight : 348g (12.50 oz)
